3 triggers configured, only 1 trigger monitored?
  • degenaro
    • Mar 2017
    • 9
    I have 3 triggers defined for host X, all WARNING: Name1, Name2, Name3.
    When I navigate to the Monitors tab for status: any, I see only 1 trigger: Name1. The lower right says displaying 1 of 1 found.
    How come? Where are the other 2? I'm pretty sure this is a newbie problem, but I'm not seeing it yet...
    Thanks.
    Lou.
  • batchenr
    • Sep 2016
    • 440
    Thanks.
    Lou.
    1. is this a triggers you set on your own or templates?
    2.when you go to hosts tab you can see how many triggers every host have - do you see 1 or 3 ?
    if you see 1 then there is only 1 trigger connected and you should figure out
    where did you set the other 2
    if you see 3 and when you get in you see 1 - its filter issue, press on ALL tab
    • degenaro
      • Mar 2017
      • 9
      I figured it out. In addition to group:all and host: all, I need to set trigger status:any and then click the blue Filter button. Now all my triggers show up, PROBLEM and OK too.
      I was trying to set trigger status and hit enter or the refresh button on my browser and that did not yield the desired result.
      • degenaro
        • Mar 2017
        • 9
        Still no joy, though.
        In Configuration I changed the names of my triggers. Under Monitoring these changes appeared. Yay!
        I have 2 triggers that are the exact opposite of each other. Name1 says PROBLEM while Name 2 says OK as expected. I then swap the expressions of Name1 and Name2. But the Monitoring -> Triggers still shows the same status even though the expressions have been swapped. And the Last change column shows a date 21 hours old even though I just changed the Expression minutes ago. Why?
        I then add 2 new triggers Name10 and Name20 which are clones of Name1 and Name2 respectively. Under Monitoring both of these triggers show as OK and Last change Never. Why?
        • degenaro
          • Mar 2017
          • 9
          The expressions for my triggers are:
          {myhost:web.test.error["[degenaro] DUCC Broker"].str(OK)}=0
          and
          {myhost:web.test.error["[degenaro] DUCC Broker"].str(OK)}=1
          I look in the zabbix logs and see no evidence that the triggers are being evaluated. Should I? If there is nothing obvious that I'm doing wrong, is there some tracing I can turn on?
