Get hosts from hostgroup and NOT from subgroups
  • olegus
    • Dec 2023
    • 73
    We have an hierarchy groups like Product/Dep/Group .
    We accidentally put some hosts in /Product/Dep instead of Product/Dep/Group and we need some how to move them down a level.
    Is it possible to achieve that in GUI?
    If I select Product/Dep group it brings all hosts from all subgroups and there is no way to filter hosts by GroupID.
    If not possible in GUI:
    I can query API to receive hosts by specific GroupID and looks like I can use host.massupdate call to replace a group but doc examples are not very clear. Can someone give me a proper host.massupdate example to replace a group?
  • Brambo
    • Jul 2023
    • 256
    on a single host: ​Click image for larger version
    or use mass update to first add the new host group and then with mass update remove the old host group. This is really basic functionality
    • olegus
      olegus commented
      Idont think it will work in my case - My first problem is how to filter hosts that only belong to /Product/Dep without selecting those that belong to Product/Dep/Group. When I filter hosts for /Product/Dep , it will also bring hosts from subgroups - Product/Dep/Group1, Product/Dep/Group2 etc. I need to mass update only these hosts that are located in /Product/Dep only and move them to, say, /Product/Dep/Group1.
  • Brambo
    • Jul 2023
    • 256
    olegus easiest way is to use tags for each host the (sub)folders are shown and as far as I know you can disable that.
    Setup you tags on the lowest folder level first with a mass update and work you way up the tree.
    e.g. in the sub folder tag hostgroup : dep/group1
    other sub group tag hostgroup : deb/group2
    etc etc and you can filter if a host has a tag hostgroup (or doesn't have it) or maybe a certain value
    • olegus
      olegus commented
      That should work , but seems too much work, API way seems better at this moment
        "jsonrpc": "2.0",
        "method": "host.massupdate",
        "params": {
            "hosts": [
                    "hostid": "ID1"
                    "hostid": "ID1"
                    "hostid": "IDn"
            "groups": [
                    "groupid": "GID1"
                    "groupid": "GID2"
        "id": 1
    I think ...
    • olegus
      olegus commented
      Yep looks like this is the fastest way...
