Zabbix trigger discover - bug
  • Ales Ulrych
    • Dec 2016
    • 36
    Hallo,
    I've created a Template to load cores Synology NAS. I recently added a condition that I not display an error in the time of the backup server. The problem is that for some reason my condition will change and I do not know why. -1 Disappears and is therefore invalid, then the trigger. I recently upgraded to version 3.2.4 zabbix. More can be seen in the video here 41eQ84CIcdw in h-t-t-p-s-:-/-/youtu-dot-be+/41eQ84CIcdw
    "Unfortunately I can not give a direct link to my uploaded video with an error and dont know how to contact administrator to make me loosen."
    Ales
  • batchenr
    • Sep 2016
    • 440
    Originally posted by Ales Ulrych
    Hallo,
    Ales
    can you post the condition and from what it change to what?
    what do you see in zabbix server logs ?
    • Ales Ulrych
      • Dec 2016
      • 36
      I do not know how to explain this strange behavior. Have you looked at the video?
      • batchenr
        • Sep 2016
        • 440
        cant reach from what u posted
        • Ales Ulrych
          • Dec 2016
          • 36
          Template Code, Trigger Prototypes: Expression:
          {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>70 and
          {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}<91 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}<230000 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}>020000
          and {Template_Synology_AU:hrDeviceCore[{#SNMPINDEX}].last(0)}<>-1
          Host trigger:
          {fileserver.interflag.local:hrProcessorLoad[196608].avg(300)}>70 and
          {fileserver.interflag.local:hrProcessorLoad[196608].avg(300)}<91 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}<230000 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}>020000
          and {fileserver.interflag.local:hrDeviceCore[196608].last(0)}<>
          missing at the end -1
          Error: Cannot evaluate expression: unexpected end of expression.
          • batchenr
            • Sep 2016
            • 440
            Host trigger:
            last(0)}<>1 only means not equal
            try doing last(-1)}=1 or last(-1)}<>1 demands on what u need
            • Ales Ulrych
              • Dec 2016
              • 36
              Incorrect trigger function "last(-1)" provided in expression. Invalid first parameter.
              • Ales Ulrych
                • Dec 2016
                • 36
                The strange thing is that this code does work:
                {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>90 and {Template_Synology_AU:hrDeviceCore[{#SNMPINDEX}].last(0)}<>-1 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}<230000 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}>020000
                It's bug. When I add a fifth condition, in the last conditions disappear parameter. Example Discovery Template:
                {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>90 and {Template_Synology_AU:hrDeviceCore[{#SNMPINDEX}].last(0)}<>-1 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}<230000 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}>020000 and
                {Template_Synology_AU:hrDeviceDescr[{#SNMPINDEX}].str("blbost")}<>1
                and Host:
                {fileserver.interflag.local:hrProcessorLoad[196608].avg(300)}>90 and {fileserver.interflag.local:hrDeviceCore[196608].last(0)}<>-1 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}<230000 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}>020000 and
                {fileserver.interflag.local:hrDeviceDescr[196608].str("blbost")}<>
                again at the end missing 1
                • batchenr
                  • Sep 2016
                  • 440
                  then solved ?
                  • Ales Ulrych
                    • Dec 2016
                    • 36
                    then solved ?
                    Unfortunately, no:
                    and Host:
                    • batchenr
                      • Sep 2016
                      • 440
                      Unfortunately, no:
                      and Host:
                      maybe like this :
                      ({Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>90) and
                      ({Template_Synology_AU:hrDeviceCore[{#SNMPINDEX}].last(0)}<>-1) and
                      ({Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}<230000) and
                      ({Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}>020000) and
                      ({Template_Synology_AU:hrDeviceDescr[{#SNMPINDEX}].str(blbost)}<>1)
                      • Ales Ulrych
                        • Dec 2016
                        • 36
                        maybe like this :
                        In a Host Trigger missing parenthesis at the end
                        ({fileserver.interflag.local:hrProcessorLoad[196608].avg(300)}>90) and ({fileserver.interflag.local:hrDeviceCore[196608].last(0)}<>-1) and ({fileserver.interflag.local:hrProcessorLoad[196608].time(0)}<230000) and ({fileserver.interflag.local:hrProcessorLoad[196608].time(0)}>020000) and ({fileserver.interflag.local:hrDeviceDescr[196608].str("blbost")}<>1
                        • batchenr
                          • Sep 2016
                          • 440
                          In a guest missing parenthesis at the end
                          then like this :
                          ({Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>90 and
                          • Ales Ulrych
                            • Dec 2016
                            • 36
                            then like this :
                            Same again for me Host Trigger missing parenthesis at the end.
                            Original:
                            ({Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].avg(300)}>90 and {Template_Synology_AU:hrDeviceCore[{#SNMPINDEX}].last(0)}<>-1 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}<230000 and {Template_Synology_AU:hrProcessorLoad[{#SNMPINDEX}].time(0)}>020000 and
                            {Template_Synology_AU:hrDeviceDescr[{#SNMPINDEX}].str("blbost")}<>1)
                            And Trigger in Host.
                            ({fileserver.interflag.local:hrProcessorLoad[196608].avg(300)}>90 and {fileserver.interflag.local:hrDeviceCore[196608].last(0)}<>-1 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}<230000 and {fileserver.interflag.local:hrProcessorLoad[196608].time(0)}>020000 and
                            • batchenr
                              • Sep 2016
                              • 440
                              #15
                              Original:
                              its all about the -1
                              look at this thred maybe it will help :
