update zabbix
  • Thomas51
    • Oct 2024
    • 19
    update zabbix
    I am currently on version 7.0.5 and I am trying to upgrade to 7.2. However, I am encountering some issues. At the end, I get the following error : Click image for larger version
    I am using Debian and Apache, and when I try to restart, I do get the login page, but I am unable to log in, and it no longer works over HTTPS.
    I have tried doing it 2-3 times and got the same result, even when specifying the path to zabbix_server.conf in the sed command. Could you please help me?"
  • Valer4uk
    • Jan 2025
    Hi there, go to cli and run systemctl status zabbix-server.service , search for error about "libldap-2.5-0", if you see such error , you can solve it by :
    wget wget http://debian.mirror.ac.za/debian/pool/main/o/openldap/libldap-2.5-0_2.5.13+dfsg-5_amd64.deb
    sudo dpkg -i libldap-2.5-0_2.5.13+dfsg-5_amd64.deb
    apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php
    • Thomas51
      • Oct 2024
      • 19
      Hello, There are no errors when I run systemctl status zabbix-server.service
      • Hamardaban
        • May 2019
        • 2714
        Do you know where the zabbix site configuration file for apache is located?
        You need to change the path to the site's home directory in this file, as /ui/ has been added to the path.
        in order to find out all apache vhosts and path run
        httpd -t -D DUMP_VHOSTS
        to
        • troffasky
          • Jul 2008
          • 639
          Debian Apache config files are in /etc/apache2/ not /etc/httpd/
