zabbix agent2 monitoring oracle database in HA mode
  • typedef75
    • Dec 2015
    • 11
    can zabbix_agent2 (with oracle plugin) installed on zabbix_server monitor remotely High-availability Oracle Database? Database connection string for this database is defined in tnsnames.ora:
    TEST =
    (DESCRIPTION =
    (ADDRESS_LIST =
    (FAILOVER = ON)
    (LOAD_BALANCE = OFF)
    (ADDRESS = (PROTOCOL = TCP)(HOST = TEST01)(PORT = 1521))
    (ADDRESS = (PROTOCOL = TCP)(HOST = TESTDRS01)(PORT = 1521))
    (CONNECT_DATA =
    (SERVICE_NAME = TEST_HA)
    If it is possible, how to correctly define connection string in zabbix_agent2 oracle item?
  • Blevar
    • Jan 2025
    • 68
    You can find info on keys and their syntax here: https://www.zabbix.com/integrations/oracle
      • 5002
      Keys is not the issue... connecting to DB is. Plugin does not seem to be able to look up required connection string, it requires user to define connection string, but if it can change...
