Zabbix agent, issues with sudo and PAM on Fedora 41.
  • Silverwolf
    • Jan 2025
    Hi everyone, I'm new to the forum and I'm stuck trying to get Zabbix to run some sudo commands.
    I tried to search around the web and the forums but found no solution to my problem.
    With the help of AI I was able make some progress and managed to run a simple ping to one of my hosts through the web interface.
    My setup:
    • Hardware: Raspberry Pi 4 Model B
    • OS: Fedora 41 (no GUI)
    • SELinux: Enforcing
    • Zabbix 7.2
    My sudoers dropin file at /etc/sudoers.d/:
    -r--r-----. 1 root root 407 Jan 18 19:14 01-zabbix-sudoers
    Content of 01-zabbix-sudoers file:
    # Allow Zabbix the sudo privilege on specific commands and folders with no password.
    # Comands alias.
    Cmnd_Alias NMAP = /usr/bin/nmap
    Cmnd_Alias PING = /bin/ping
    # Don't require terminal for the commands of the user zabbix.
    Defaults:zabbix !requiretty, !syslog, !pam_session
    # Allow zabbix user to execute sudo commands without password.
    zabbix ALL=(root) NOPASSWD: PING
    zabbix ALL=(root) NOPASSWD: NMAP
    On the log file of the Zabbix server at /var/log/zabbix/zabbix_server.log I still get this error no matter what I do:
    55200:20250118:191634.689 Failed to execute command "sudo /usr/bin/nmap -O 192.168.1.11": sudo: PAM account management error: Permission denied
    sudo: unable to send audit message: Permission denied
    sudo: a password is required​
    Content of the file /etc/pam.d/sudo:
    #%PAM-1.0
    auth       include      system-auth
    account    include      system-auth
    password   include      system-auth
    session    optional     pam_keyinit.so revoke
    session    required     pam_limits.so
    session    include      system-auth
    I corrected all errors on SELinux related with Zabbix permissions and accesses:
    [user@mchine ~]# sudo sealert -a /var/log/audit/audit.log
    100% done
    found 0 alerts in /var/log/audit/audit.log​
    Still I'm unable solve this error. This is what I get on the GUI em I click on the host and try to run the built-in script "Detect operating system":​
Name:	zabbix error.png
    I also tried to add the user zabbix to the wheel group with no effect.
    Any help or tip in the right direction would be greatly appreciated.
    Thanks in advance.​
  • Blevar
    • Jan 2025
    • 68
    Have you added user zabbix to sudoers?
    sudo visudo -c
    • Silverwolf
      • Jan 2025
      The dropin file should set zabbix user in the sudoers as stated on previous post. Some of the commands are running with sudo already so I believe this is not the issue but something related with PAM.
      On this website I found some information about PAM but can't make any sense of what I may be missing:
      Pluggable Authentication Modules (PAM) have been around since 1997. I was taught that PAM originated from Sun's Solaris, and it does appear that the first en...
      The file looks parsed correctly:
      sudo visudo -c
      /etc/sudoers: parsed OK
      /etc/sudoers.d/01-zabbix-sudoers: parsed OK​
