unable to preprocess timestamp
  • blackbasket
    • Jan 2025
    • 13
    Hi community,
    I am trying to convert a given timestamp into date format to compare it. If I try, I always get NaN or invalid date in ZABBIX 7.0, but in JavaScript test page (https://developer.mozilla.org/en-US/...cts/Date/parse) ist is working. I tried with and without timezone. Same results.
    May someone help me please?
    Preprocessing:
    JavaScript:
    var a = Date.parse(value);
    return a;​
    Regards,
    Marcel
  • Brambo
    • Jul 2023
    • 256
    First try your jsonpath and add .first() to the path, this should get rit of those brackets
    Second I believe const and let aren't available in duktape javascript so use var for your variables.
    As I'm no javascript guru I would suggest to take a look at: https://www.zabbix.com/forum/zabbix-...ersion-problem
    • blackbasket
      • Jan 2025
      • 13
      Thank you, Brambo... the link helped... obviously I was to stupid to search for the right phrase
      BTW: In the zabbix code (see the code tag) I used var
      • benisfroms
        • Aug 2025
        I see what you mean, and I agree — parsing timestamps can behave differently depending on the environment, which makes debugging in Zabbix a bit tricky compared to JavaScript directly in the browser. Sometimes the preprocessing step in Zabbix requires a custom transformation rule rather than relying on native parsing.
        • benisfroms
          • Aug 2025
