zabbix remote hosts reporting data but availability unknown
  • infusedhosting
    • Jan 2025
    Hi all
    Setup zabbix server and 2 remote servers so far. Looking to use zabbix to monitor a number of cpanel & directadmin hosts.
    Ive installed the agent on 2 cpanel hosts, allowed the 2 ports through the firewall and added a couple of basic monitoring templates.
    Both hosts are showing data in the dashboards for cpu, disk, network but both hosts availability shows unknown.
    Any advice would be appreciated.
    ThankyouClick image for larger version
  • Blevar
    • Jan 2025
    • 68
    How are your agents on host configured? Sharing config files would be helpful.
    • troffasky
      • Jul 2008
      • 639
      If Zabbix agent is not new enough, in Active mode, Zabbix server will receive metrics but the Availability will just show as unknown.
      I cannot remember which version is required to get a green light here.
