Printers Map
  • Luís Nereu Feder
    • Jan 2025
    • 33
    Printers Map
    Hello, I'm creating a printer map, and I need to have the information about the name, IP address and the page counter. I don't know which macro I can use to bring the page counter information, can someone help me?
    I got the IP and name information, I just need the page counter
Name:	Mapa de Impressoras.png
  • Blevar
    • Jan 2025
    • 68
    It realy depends on many things. Are you using any premade templates? Or your own templates/items. If so - there is no way anyone except for you can answer this question. Or are you looking for suggestions of how to name such macro?
    You can look for buildin macros: https://www.zabbix.com/documentation...ed_by_location but i think that in your case you would need to create your own.
    • Luís Nereu Feder
      • Jan 2025
      • 33
      The item that brings the page counter information was created by me, that is, I am looking for suggestions on how to name such a macro.
      • PZakrzewski
        • Dec 2024
        • 12
        hey,
        That's really up to You. Just make sure the naming of macro is unique and You don't have any other macros named with the same name.
        • kyus
          • Feb 2024
          • 203
          Hey!
          Since you have an item that displays the page counter info.
          Just like you added those macros in the element label, you can simply add this syntax:
          {?last(/host/your.item.key)}
          • Luís Nereu Feder
            • Jan 2025
            • 33
            hey
            I used this syntax, but it gave me an unknown value, maybe I'm forgetting something​
            • kyus
              • Feb 2024
              • 203
              What is your Zabbix server version?
              In your map, if you're using a element of "Type": "Host Group" and "Show": "Host group elements" you should omit the host in that syntax, so it would be like:
              {?last(//your.item.key)}
              • Luís Nereu Feder
                • Jan 2025
                • 33
                I'm on version 7, I tested it and it worked, thank you very much
