Postgresql update from 15 to 17 with TimescaleDB
  • Sined_r
    • Jun 2024
    • 12
    I would like to migrate my Zabbix server to a new VM and upgrade the somewhat older PostgreSQL version, but then I have the problem that my graphs displaying data older than 7 days are partially defective.
    Zabbix LTS 7 on debian 12 with php and nginx
    First I upgraded the timescale DB version to 2.7.2:
    sudo service zabbix-server stop
    sudo service zabbix-agent stop
    su postgres
    psql -X
    \c zabbix
    ALTER EXTENSION timescaledb UPDATE TO '2.17.2';
    after a restart I have no errors in the log or on the web interface.
    When updating the Postgresql database
    sudo apt-get -y install postgresql-16
    sudo apt-get -y install timescaledb-2-postgresql-16='2.17.2*' timescaledb-2-loader-postgresql-16='2.17.2*'
    sudo pg_lsclusters
    sudo pg_dropcluster 16 main --stop
    sudo pg_upgradecluster 15 main
    sudo pg_dropcluster 15 main
    sudo apt purge postgresql-15 postgresql-client-15 -y
    sudo pg_lsclusters
    but I get many such errors:
    pg_restore: error: could not execute query: ERROR: operation not supported on chunk tables
    The statement was: ALTER TABLE _timescaledb_internal._hyper_1_5960_chunk DISABLE TRIGGER ALL;
    The values of the items all seem to be retrievable.
    But when I want to view the items in a graph, I often get the following error:
    Click image for larger version  Name:	image.png Views:	0 Size:	43.5 KB ID:	497573
    Unfortunately, I can't get a better display of the error
    Click image for larger version  Name:	image.png Views:	0 Size:	18.1 KB ID:	497574​I have also tried to create a dump, then go to 16 and import the dump again. Same behavior.
    Any idea how I can fix this problem?
    Thanks for your help!!!​
