close zabbix problem with "x" number of days
  • dharam
    • Oct 2024
    • 26
    Hi All,
    I am looking to automate to close zabbix problem with "x" number of days , can anyone help me with pointer on this , i was looking into documents and looks like some API are available but I am not sure how to use it.,
  • troffasky
    • Jul 2008
    • 639
    This is not built in to Zabbix.
    Every trigger would need to have "Allow manual close" enabled on it. Then you can [ask ChatGPT to] write a script which uses the API to close every open trigger over a certain age and run it hourly from cron, or whatever.
    However....that's a complicated way to achieve something, which you could achieve simply by ticking "Age less than N days" on triggers view.
