Add option to walk
  • yvan34
    • Jan 2025
    Add option to walk
    I have a MIB that use the char "_" in.
    To walk, it's needed to add option to snmpwalk --> -Pu (this option is allow "_" in MIB)
    In zabbix, when i use this MIB, i got the same error than snmpwalk when i don't use option -Pu.
    ########### Sample
    The mib is for Zyxel GPON OTL1404
    The command without option Pu :
    snmpwalk -v3 -a SHA -A mypass -x DES -X mypass -l authPriv -u myuser MYHOST ZYXEL-olt1404-MIB::ifGponPortName
    The result :
    Expected "(" (_): At line 7507 in /usr/share/snmp/mibs/OLT1404.mib
    Should be ACCESS (as): At line 7507 in /usr/share/snmp/mibs/OLT1404.mib
    Bad parse of OBJECT-TYPE: At line 7507 in /usr/share/snmp/mibs/OLT1404.mib
    ZYXEL-olt1404-MIB::ifGponPortName: Unknown Object Identifier
    The command with option Pu :
    snmpwalk -Pu -v3 -a SHA -A mypass -x DES -X mypass -l authPriv -u myuser MYHOST ZYXEL-olt1404-MIB::ifGponPortName
    The result :
    ZYXEL-olt1404-MIB::ifGponPortName.1 = STRING: "pon-1"
    ZYXEL-olt1404-MIB::ifGponPortName.2 = STRING: "pon-2"
    ZYXEL-olt1404-MIB::ifGponPortName.3 = STRING: "pon-3"
    ZYXEL-olt1404-MIB::ifGponPortName.4 = STRING: "pon-4"
    ZYXEL-olt1404-MIB::ifGponPortName.5 = STRING: "eth-1"
    ZYXEL-olt1404-MIB::ifGponPortName.6 = STRING: "eth-2"
    In Zabbix log, i found exactly the same error massage when i do not use the option Pu
    ################ END Sample
    My question : Where can i put this option in Zabbix for walking this MIB ?
    Thanks for help
