Hi there,
I am doing the zabbix db mysql schema upgrade 1.8 to 2.0. Using the download package from zabbix and use the following command to upgrade zabbix database schema from 1.8 to 2.0:
mysql -uroot -ppassword zabbix3 --verbose < /tmp/zabbix-2.0.20/upgrades/dbpatches/2.0/mysql/patch.sql
It failed on below error:
ERROR 1034 (HY000) at line 1862: Incorrect key file for table 'events'; try to repair it
environemnt:
Centos 7.3.1611
Mariadb 10.1.21
I did try below, but it still failed.
[root@ tmp]# mysqlcheck -u root -p --auto-repair zabbix events
Enter password:
zabbix.events OK
MariaDB [zabbix]> analyze table events;
| Table | Op | Msg_type | Msg_text |
| zabbix.events | analyze | status | OK |
1 row in set (0.86 sec)
MariaDB [zabbix]> check table events;
| zabbix.events | check | status | OK |
1 row in set (10 min 52.83 sec)
MariaDB [zabbix]> optimize table events;
| zabbix.events | optimize | note | Table does not support optimize, doing recreate + analyze instead |
| zabbix.events | optimize | error | Got error 64 'Temp file write failure' from InnoDB |
| zabbix.events | optimize | status | Operation failed |
3 rows in set, 1 warning (56.14 sec)
Change the tmp folder to /opt/mysql/tmp
increate size from 256M to 1G
[root@ zabbix]# mysql_upgrade -uroot -ppassword zabbix
Phase 1/6: Checking and upgrading mysql database
Processing databases
mysql
mysql.column_stats OK
environemnt:
Centos 7.3.1611
Mariadb 10.1.21
Enter password:
zabbix.events OK
mysql
