Why Do Printers Have Agents?
  • jbrussich
    • Feb 2017
    For some reason, zabbix keeps adding the Agent Interface on my printer host.
    Even when I delete the Agent Interface (because my printers only talk SNMP) and I recheck some time later, the agent Interface is re-added.
    Is there a way to permanently remove the agent interface for my printers?
    Last edited by jbrussich; 25-03-2017, 18:20. Reason: topic change -> question answered / Problem resolved
  • rthonpm
    • Jan 2016
    • 41
    I haven't seen this issue: what version of Zabbix are you using?
    Does it keep re-populating the field as well, or can you just leave it blank?
    • kloczek
      • Jun 2006
      • 1771
      Interface definition is almost since-always ;P
      maybe not always but very long time.
      About agent interface.
      Agent interface will be used only if set of metrics will have any "zabbix agent" or "zabbix (active) agent" type keys.
      Just ignore this part.
      • jbrussich
        • Feb 2017
        Zabbix 3.2.4.
        Maybe because of the auto-disovery Rule?
        • sergio.cricca
          • Mar 2008
          • 43
          Agent interface is used also for ICMP ping checks, for example.
          I suppose it's getting configured because in your discovery (or maybe in your template too) you use ICMP Ping.
          • jbrussich
            • Feb 2017
            Right you are, Madam or Sir.
            A new discovery rule (without the ICMP) does not add the agent.
            Thank you!
