Network interface "Bits received" is cumulative instead of per second
  • xofer
    • Jul 2010
    • 18
    Somehow one of my machine's incoming bits are cumulative:
    Click image for larger version  Name:	Screenshot 2025-01-24 at 16.30.54.png Views:	0 Size:	136.2 KB ID:	497840
    Somehow, I doubt that it actually receives 80Gbps on a 1 Gbps link ;-)
    The item is autodiscovered by "Windows by Zabbix agent" template.
    The preprocessing does seem to define that it should be per second:
    Click image for larger version  Name:	Screenshot 2025-01-24 at 16.34.50.png Views:	0 Size:	35.3 KB ID:	497841​
    What am I missing?
    Zabbix version is 7.0.6.
  • Blevar
    • Jan 2025
    • 68
    This is a graph of bits recieved... It will grow the more data you download. This has nothing to do with network speed.
    • xofer
      • Jul 2010
      • 18
      As I posted, the "preprocessing steps" for the item says "Change per second" - does it not apply to the graph of the same item?
      Anyway the main issue was that "Interface Intel(R) 82574L Gigabit Network Connection(Ethernet): High bandwidth usage" was triggered on this item shortly after starting and stayed until next reboot.
      • xofer
        • Jul 2010
        • 18
        Here is a graph from a different host, different NIC. Same "Windows by Zabbix agent" template. This is what I would expect.
Name:	Screenshot 2025-01-28 at 17.18.57.png
          But what causes it to drop to 0 sometimes? Reboots?
          Maybe that NIC gives out some weird values? Still that "change per sec" should avoid constant growth... "test all steps", what that shows? reasonable values ?
          • xofer
            • Jul 2010
            • 18
            Yes, drops are restarts.
            Maybe, but I got restless and changed the NIC (it was in a VM) from Intel to virtio and now it is normal.
            What baffled me the most was that it wasn't even strictly cumulative - it went up and down with a cumulative trend as you can see from graph.
