adding constant value to macro in key
  • ccaron
    • Jan 2025
    Do I have a way to add a constant value to key values in template
    I tried modbus.get[{$ENDPOINT},,3,{?{$REGISTER}+14},1,float,,] and a lot of other options but always receive an error
    Thanks for your help
  • Blevar
    • Jan 2025
    • 68
    You cant perform direct aritmethic operations in this case. Try changing the {$REGISTER} value in preprocessing.
      You cannot really do that either...
      But if you are using user macros, what you define by yourself... why you cannot define correct value right away?
      • ccaron
        • Jan 2025
        My m-bus adapter can read up to 500 counters. Each counter use a separate set of 20 registers.
        I can create 20 macro with the address of each register but il will be easier to create one macro for the base address and add an offset for each key
          I guess you could write a JS item that produces json, required for LLD as output and then you can run a discovery on top of that to create all required items.
          Or at least have that file somewhere to be read with vfs.file.content item or something ..
