Host monitoring via ICMP
  • mvoltolini
    • Jan 2025
    Good morning, everyone,
    I am a new Zabbix user and I am starting to take my first steps with this software. In the installation I am testing I have successfully managed to establish the connection between the Zabbix Server instance and two clients using the agent.
    I have configured a host that I need to keep monitored via ICMP because I don't have the ability to install the agent on the machine.
    Following some tutorials I did this:
    1. Verified that fping was updated to the latest version
    2. changed the property of fping with chown root:zabbix /usr/bin/fping
    3. added to the Zabbix server configuration file StartPingers=10 and FpingLocation=/usr/bin/fping
    4. restarted zabbix via systemctl restart zabbix-server (I also did a reboot of the VM)
    After adding the ICMP template and saving the host however, I cannot display any data.
    ​What am I doing wrong?
  • Blevar
    • Jan 2025
    • 68
    What does Latest data tab say for said host? Is there any error displayed near the item?
    • jean-louis.abegg
      • Feb 2020
      • 37
      Watch out for firewall rules too.
      You could realise tests from the cli of your zabbix, to check if 192.168.1.50 respond to your echo icmp.
      fping 192.168.1.50
