Zabbix LLD Macros and filters
  • chintan1
    • Jun 2022
    • 24
    Hello All,
    Need your help with lld Macros and filters in discovery
    I have created an item of type http where I am running Prometheus query and fetching json data.
    Using this item I have created a dependent discovery where I am using preprocessing as $.data.metrics[*].metrics
    From this I m fetching multiple lld macros.
    I have a metric named Ab_serive which contains name like abx-main abx- backup
    I am storing {#abc1} $.ab_service
    {#abc2} $.ab_service storing same values in both macros.
    While applying filters
    Abc1 matches .*main
    Abc2 matches .*backup
    Or
    Abc1 matches .*main
    Abc1 doesnotmatch .*backup
    Abc2 doesnot matches .*main
    These filters are not working as expected any suggestions?
  • chintan1
    • Jun 2022
    • 24
ID:	498128Click image for larger version
ID:	498131​Click image for larger version
ID:	498132​$.data.result[?(@.metric.mk_service=='{#MK_SERVICE_BACKUP}' && @.metric.channel_name=='{#CHANNEL_NAME}')].value[1]
    Json data:
    {"__name__":"mk_rt_tx_rate_mbps","account_id":" f94-48a5-8f13-635283cc8a48","account_name":"sss","backup_source_ id":"534a99ba84f90dee90f115","channel_id":"15bb0 88 70b1a71650e","channel_name":"ND","cloud":"azure"," container":"srt","endpoint":"http-metrics","env":"nb-c","env_type":"live","instance":":49365","job": "sr t-worker","main_source_id":"d7dd17485da83f643be93eec 59","mk_service":"1-mkn-backup","mode":"udp","namespace":"med","native":"t rue","pod":"srt-1-mkn-backup-srt-1-99c7-2qg54","prometheus":"med/metrics-kube-prometheus-st-prometheus","prometheus_replica":"prometheus-metrics-kube-prometheus-st-prometheus-0","region":"eastus2","service":"srt-1-mkn-backup-srt-1","zone":"eastus2"},"value":[1738127893,"34.358016"]},
    {"__name__":"mk_rt_tx_rate_mbps","account_id":" f94-48a5-8f13-635283cc8a48","account_name":"sss","backup_source_ id":"534a99ba84f90dee90f115","channel_id":"15bb0 88 70b1a71650e","channel_name":"ND","cloud":"azure"," container":"srt","endpoint":"http-metrics","env":"nb-c","env_type":"live","instance":":49365","job": "sr t-worker","main_source_id":"d7dd17485da83f643be93eec 59","mk_service":"1-mkn-main","mode":"udp","namespace":"med","native":"t rue","pod":"srt-1-mkn-backup-srt-1-99c7-2qg54","prometheus":"med/metrics-kube-prometheus-st-prometheus","prometheus_replica":"prometheus-metrics-kube-prometheus-st-prometheus-0","region":"eastus2","service":"srt-1-mkn-backup-srt-1","zone":"eastus2"},"value":[1738127893,"34.358016"]},​
    • kyus
      • Feb 2024
      • 203
      Hey!
      So, when you say your filters aren't working, what do you exactly mean?
      Are your items not being created in the Host?
      Are they being created but with the wrong values?
      • chintan1
        • Jun 2022
        • 24
        Hi kyus,
        Without filters it discovers both the metrics of mk_service
        With filters everything gets undiscovered:
ID:	498166Click image for larger version
        • chintan1
          • Jun 2022
          • 24
          And with both as doesn't match, it filters both main and backup which gives rest everything
          • kyus
            • Feb 2024
            • 203
            I'm not sure if the fact that you extracted the same value to 2 macros can be a problem, but you can test it, just to make sure.
            You don't really need 2 macros for what you want.
            Try removing both {#MK_SERVICE_BACKUP} and {#MK_SERVICE_MAIN}.
            Create a single {#MK_SERVICE} macro.
            In filters add a filter {#MK_SERVICE} matches .+backup|.+main
            Hope it helps
            • Kos
              • Aug 2015
              • 3469
              unfortunately, it is not very clear for me what is your purpose.
              As well, to advice something useful, it's necessary, at least, the following information:
              • version of your Zabbix server;
              • example of JSON that is the source for your LLD rule.
              • chintan1
                chintan1 commented
                Thank you @Kos
                Version is 7.2
                Source you mean the initial json data before preprocessing?
              • Kos
                Kos commented
                If possible, after preprocessing; but exactly JSON used for LLD, not for item prototypes (if they differ).
            • chintan1
              • Jun 2022
              • 24
              kyus,
              I am actually looking for 2 item prototypes. One with main and another with backup so trying to filter main from backup and back up from main macros but it's not working
              • kyus
                • Feb 2024
                • 203
                Since both item prototypes seem to be equal, it won't really change anything if you had only one macro extracting both values...
                Well, it does look like either some error in your regex matching (it seems fine to me) or some unexpected behaviour in your preprocessing steps
