Host Navigator widget - how to set default view?
  • tcweb
    • Jun 2024
    • 57
    I have created a host navigator widget, sorted by host group, and tags. It works as expected. But when I first go to the dashboard screen, one of the host groups is expanded. The others are collapsed.
    I assumed it may be because it was that way the last time I saved the changes to the dashboard, but that does not appear to be the case.
    I have a theory: since I have items that populate based on the host selected, which ever host is first in the host selection list will be expanded, and visible when the page loads.
    After playing around a bit, I CAN save the widget with other host groups expanded. But no matter what I do, that very first one always stays expanded.
    It would be cool feature to set a "default" selected host in the host navigator widget.
    maybe its "Order by hostid"??
    • tcweb
      • Jun 2024
      • 57
      Hi cyber, not sure what you are saying. The host navigator widget does not have an order by option. (there is group by, which I have set to Host Group first, then Tag value)
      My question is really about grouping (grouping seems to work as expected), and specifically which "groups" are expanded or not.
      sorry if my question was not clear. Thanks for your help!
      -Tom
        yea, bad explanation from my side... But let it be.. it was just a runaway thought...
