SNMP Trap value in Trigger
  • pcraponi
    • Oct 2012
    • 15
    Hi, I use snmptt to collect my SNMP Traps. It's working fine...
    Now, I want to get some TRAP value to use in the Trigger Name.
    For example, in my snmptt.conf I have:
    EVENT fnTrapPowerSupplyFailure .1.3.6.1.4.1.12356.100.1.3.0.106 "fnTrapPowerSupplyFailure" Normal
    FORMAT ZBXTRAP $aA $ar - VALUES: $1 $2
    I need get the $2 and use in the trigger.
    I'm using ZBX 3.0
    Thanks in advance,
    Paulo R.
  • slagmaur
    • Nov 2016
    Zabbix 3.4 allow to do macro functions, that might help you out https://www.zabbix.com/documentation...acro_functions
    • ppn3
      • May 2018
      Is it supported ti use the above mentioned macro functions in {ITEM.VALUE} in trigger name?
