Hey,
Is there any way to configure a honeycomb widget to only show hosts that have a certain value larger than X?
What I'm trying to accomplish, is a honeycomb widget that will only show hosts with disk space available lower than 10% and then color it yellow to red depending on how full the drive is.
Currently I'm only struggling with how to filter out hosts that are fine. I'm currently showing all hosts even if they only use e.g. 1% of disk space.
I'm not sure what the best method would be to do this.
Thanks for any input!
-Maarten
-Maarten
