Zabbix LLD problem
  • hakanozanlagan
    • Nov 2021
    • 35
    Zabbix LLD problem
    Hello, I am configuring an LLD Macro with the $.data jsonpath query in a json file as below. The $.data query loading the "data_1, data_2, aaa_1, aaa_2" values in the json into the Macro. I need to load only data_1 and data_2 into the macro with using "data" keyword. is there a way to do this?
    "data": "data_1",
    "value": "1"
    "data": "data_2",
    "value": "2"
    "data": "aaa_1",
    "value": "104.0"
    "data": "aaa_2",
    "value": "0.0"
  • Hamardaban
    • May 2019
    • 2713
    There is a way!
    Read the documentation carefully and completely…
    Pay attention to the "Filter" section.
    {#DATA}=$.data
    {#DATA} matches ^data_\d+$
    • hakanozanlagan
      • Nov 2021
      • 35
      Originally posted by Hamardaban
      There is a way!
      {#DATA}=$.data
      Hello Hamardaban,
      thanks for reply, problem solved.
      I created 2 LLD macro with same query but filtered with different regex.
