Monitoring of cloud systems (HTTP/PING request)
  • Bitz0r
    • Jan 2025
    • 22
    Hey guys,
    I would be interested to know how you ‘monitor’ cloud systems.
    I'm really talking about a rudimentary check - is that yes or no?
    Example:
    Among other things, I have our website and then other cloud systems such as
    Trend Micro Portal, Meraki Portal etc. I would like to simply make a URL query or an HTTP request.
    How do you do that? Do you go to the Zabbix host and store an ‘item’ with net.tcp key or what is your solution for such monitoring?
  • kyus
    • Feb 2024
    • 203
    Hey!
    Maybe HTTP Items are what you're looking for?
    • Bitz0r
      • Jan 2025
      • 22
      You saved me, it was obivous.. Thank you..
      One little question. Do you use Zabbix in a Docker Enviorment with SNMP traps?
      • kyus
        • Feb 2024
        • 203
        I have some installations of proxies in docker containers, but they're only using Zabbix agent items.
