How to see data get from a plugin in zabbix GUI
  • frazou1
    • Feb 2025
    Im new with Zabbix and i lost. I configure the MSSQL by Zabbix agent 2 and add the macro as documented into my host. Now, i dont understand where i can't find the value of that and if working or not. In my zabbix agent log i dont see any errors.
    Did you at least assigned that template to a host?
    After that you shoudl see your data under "latest data" section.
