Zabbix 7.2 Agent2 MQTT Plugin issue: cannot open CA file for TLS connection
  • qds013
    • Oct 2023
    Hello everyone,
    Debian 12 Bookworm
    Zabbix 7.2.3
    Agent2
    I have a problem trying to setup secure MQTT connection with Agent2 MQTT plugin: Agent2 cannot find/open CA file
    2025/02/05 10:29:47.029785 [101] adding new request for key: 'mqtt.get["tls://<mqtt-server>8883", "$SYS/broker/uptime", "<username>", "<password>"]'
    2025/02/05 10:29:52.009903 sending [{"request":"agent data","data":[{"id":1,"itemid":48483,"state":1,"value":"open \"/etc/ssl/certs/ca_mqtt.crt\": no such file or directory","clock":1738740587,"ns":32681857}],"session":"36c21d95dbb12724687845f0a2200191","host":"zabbix-server","version":"7.2.3","variant":2}] to [127.0.0.1:10051]
    /etc/zabbix/zabbix_agent2.d/plugins.d/mqtt.conf
    Plugins.MQTT.Default.TLSCAFile="/etc/ssl/certs/ca_mqtt.crt"
    ls -al /etc/ssl/certs/ca_mqtt.crt
    -rw-r--r-- 1 root root 1464 Apr 25  2024 /etc/ssl/certs/ca_mqtt.crt zz0.yrzw6syzimrzz
    In the meantime, mosquitto_sub works just fine with exactly the same CA file
    mosquitto_sub -h <mqtt-server> -t '$SYS/broker/version' -p 8883 -u <username> -P <password> -C 1 --insecure  --cafile /etc/ssl/certs/ca_mqtt.crt -v
    $SYS/broker/version mosquitto version 2.0.11
    Any idea, please?
    crt file is owned by root. Even if it has read permissions for "others", is there similar permissions in whole path, so others (zabbix) can get to file?
    "namei -mo /etc/ssl/certs/ca_mqtt.crt" should give you all permissions along the path.
    • qds013
      • Oct 2023
      Yeah, I checked that - doesn't look like access permission is an issue here:
      f: /etc/ssl/certs/ca_mqtt.crt
      drwxr-xr-x root root /
      drwxr-xr-x root root etc
      drwxr-xr-x root root ssl
      drwxr-xr-x root root certs
      -rw-r--r-- root root ca_mqtt.crt
      sudo -u zabbix cat /etc/ssl/certs/ca_mqtt.crt
      -----BEGIN CERTIFICATE-----
      MIIECzCCAvOgAwIBAgIUSIIeRHhBycLqOP+jsRd5Ze3h5FIwDQ YJKoZIhvcNAQEL
      ​XI7wVYly8sNPCqov2ljrnImjeOB5fyef2wq7JsRtfA==
      -----END CERTIFICATE-----
      ​Can it be a problem with Agent2 itself?
