Log file reading with matching AND not-matching keywords
  • infraq
    • Aug 2024
    Hello all,
    i'm trying to get Zabbix to be able to read log files, which is working, but not completely as I was hoping for.
    The goal is to use a matching filter to filter out the desired lines from a log file, but not if the non-matching filter also matches.
    Think of it like reading a log file for entries "virus found" vs "no virus found", where entries should trigger an alert is matched with "virus found" , but not if the line reads "no virus found".
    However, I'm struggling to get the logic of the item and trigger operational.
    For the item itself, I can get it working by only using the positive match found, but I fail to see how to implement the check for the negative match.
    When I change the value of {$LOG_FILTER.RESULT} to "(skipping)" (without quotes), the item and trigger work, but that's only half the story. It seems to not be possible to reference a macro from another macro?
    How can I get a positive match and negative match operational at the same time?
    Thank you in advance for any possible solution and/or hint
  • Brambo
    • Jul 2023
    • 256
    I do it like the following (in 1 regex)
    - \[DBv.\] (Error .*|\[text I want.*|^(?!Text I don't want)|.*second text i want.*)
    My text lines start with yyyyMMdd - [DBvX] ..... rest of the text that is why i have the DBv. and \] \[ lines in there. The yyyyMMdd is filtered with Log time Format
    • infraq
      infraq commented
      Thank you for the suggestion, I'll use that.
