creating widget - interface traffic
  • VladJack
    • Feb 2025
    creating widget with some data from linux machines, however snmp data in zabbix contains interface alias and it it different for servers we have, examples:
    Interface eth1(External): Bits sent
    Interface eth1(Internal): Bits sent
    Interface eth1(dmz): Bits sent
    How in widget we can skip interface alias and display data from all servers eth0 interface?
    something like:
    Interface eth1(*wildcard*): Bits sent
    Thank you
  • kyus
    • Feb 2024
    • 203
    Interface eth1* Bits sent
    • VladJack
      • Feb 2025
      Have already tried this, doesn't works
      • Brambo
        • Jul 2023
        • 256
        Then u probably use the wrong widget
        My host names are link: productname node 1, productname node 2 that is why I have * around the word node, to give sent and receive a different color you can do it link in the right part of the screenshot.
        • VladJack
          • Feb 2025
          Want to use "Top hosts" widget, want include network traffic data in columns:
          • kyus
            • Feb 2024
            • 203
            You can't use regex on Top Hosts items. The ideia is to display the same item across multiple hosts.
            I'm just unsure, why would you want to display network traffic in top hosts?
            This way you won't be able to see the usage over time
