Minimum required PHP version is 8.0.0.
  • Danizak
    • Feb 2025
    I have read several things about this type of error (Minimum required PHP version is 8.0.0.), but none really gave an answer, for what I searched.
    I had this problem and I solved it by uninstalling Zabbix and reinstalling it but after a while it appeared. When I go to read the problem on the php8.4 start, the problem is the following: "ERROR: Another FPM instance seems to already listen on /var/run/php/zabbix.sock". I tried to delete this file and Zabbix worked for a certain amount of time until it decided not to work anymore and always gave me the same problem.
    What is the definitive solution?
    P.S.: on the Zabbix web config I changed the Sock to use php8.4-fpm. It works but in the dashboard several errors appear
    Here /etc/zabbix/nginx.conf
            location ~ [^/]\.php(/|$) {
                    fastcgi_pass    unix:/var/run/php/zabbix.sock;
                    fastcgi_split_path_info ^(.+\.php)(/.+)$;
                    fastcgi_index   index.php;
                    fastcgi_param   DOCUMENT_ROOT   /usr/share/zabbix;
                    fastcgi_param   SCRIPT_FILENAME /usr/share/zabbix$fastcgi_script_name;
                    fastcgi_param   PATH_TRANSLATED /usr/share/zabbix$fastcgi_script_name;
                    include fastcgi_params;
                    fastcgi_param   QUERY_STRING    $query_string;
                    fastcgi_param   REQUEST_METHOD  $request_method;
                    fastcgi_param   CONTENT_TYPE    $content_type;
                    fastcgi_param   CONTENT_LENGTH  $content_length;
                    fastcgi_intercept_errors        on;
                    fastcgi_ignore_client_abort     off;
                    fastcgi_connect_timeout         60;
                    fastcgi_send_timeout            180;
                    fastcgi_read_timeout            180;
                    fastcgi_buffer_size             128k;
                    fastcgi_buffers                 4 256k;
                    fastcgi_busy_buffers_size       256k;
                    fastcgi_temp_file_write_size    256k;
