NTP monitoring: Comparing SNMP-based time offset with Zabbix system time
  • kyus
    • Feb 2024
    • 203
    #16
    You can create an item in the "Zabbix server" host that retrieves system.localtime
    • HideOnBush
      • Feb 2025
      • 12
      #17
      There is an item in the Zabbix server; how do I "connect" the two different items on two different hosts with a trigger?
      • kyus
        • Feb 2024
        • 203
        #18
        Originally posted by HideOnBush
        Like: last(/NTP/ntp.convert)-last(/ZabbixServer/system.localtime)>15
        Basically like this. You'll notice that the trigger will appear in both hosts (only 1 event will be generated in case of problem).
        • HideOnBush
          • Feb 2025
          • 12
          #19
ID:	500252Ever the same problem, I made the trigger with two different hosts but is not collecting data
          • kyus
            • Feb 2024
            • 203
            #20
            Well this is a problem with your items, not the trigger.
            You need to find out why your items can't collect data, it can be either ntp.convert or system.localtime that aren't working as expected
