MS Teams Webhook Problem After Upgrade to 7.2
  • DaveS
    • Dec 2023
    • 10
    After upgrading to Zabbix 7.2.3, I can no longer receive Zabbix alerts in MS Teams. I keep getting the error:
    • Sending failed: Error: cannot get URL: Couldn't connect to server.
    I re-installed MS Teams yaml file that is supposedly for 7.2. I verified that the Teams channel webhook URL is up to date and correct. Everything was working fine, then immediately after the Zabbix upgrade I started getting this error.
    Anyone have a solution or know what the issue could be?
  • DaveS
    • Dec 2023
    • 10
    Update: I've seen some confusing info about whether or not MS Teams has deprecated Connectors so I created a new MS Teams "workflow" following the instructions outlined here:
    https://git.zabbix.com/projects/ZBX/...Frelease%2F7.2
    I am getting the same error "cannot get URL".
    What URL is this referring to? Is it the webhook URL to MS Teams or is it my host URL? I can't seem to figure this out. Any help or ideas would be appreciated.
    • DaveS
      • Dec 2023
      • 10
      Update: Finally figured out my issue...at least for the workflow...
      In the MS Teams Workflow media type, a parameter of http_proxy and point it to the proxy server I use for internet connection.
