Zabbix can't find fping
  • Phalle
    • Feb 2025
    .New install of Zabbix 7.2.3 on Ubuntu 24.04.
    When I set up a discovery I get error 'ICMP ping' checks failed: "At least one of '/usr/sbin/fping', '/usr/sbin/fping6' must exist. Both are missing in the system
    I did some googeling and tried to fix the permissions but without success. I'll paste the config below. Is there anything that is wrong?
    cat /etc/group
    zabbix:x:111:zabbix
    netadmin@zabbix01:~$ groups zabbix
    zabbix : zabbix
    ls -la /usr/sbin/fping*
    lrwxrwxrwx 1 root root 14 Feb 15 06:13 /usr/sbin/fping -> /usr/bin/fping
    ls -la /usr/bin/fping*
    -rws--x--- 1 root zabbix 52088 Feb 7 2022 /usr/bin/fping
    lrwxrwxrwx 1 root root 5 Feb 7 2022 /usr/bin/fping6 -> fping
    grep FpingLocation /etc/zabbix/zabbix_server.conf
    ### Option: FpingLocation
    FpingLocation=/usr/bin/fping
    I tried both /usr/bin/fping and /usr/sbin/fping as location but none of them worked.
  • jdupree
    • Feb 2025
    I have the same issue as well.
    • PavelZ
      • Dec 2024
      • 172
      This is distribution specific settings.
      Setup FpingLocation=/usr/bin/fping for Ubuntu in file /etc/zabbix/zabbix_server.conf.
      No problems on fresh Ubuntu installation with default apparmor settings and filesystem settings.
      PHP Code:
      Distributor ID: Ubuntu
      Description
      : Ubuntu 24.04.2 LTS
      Release
      : 24.04
      Codename
      : noble
      ls
      -la /usr/bin/ping
      -rwxr-xr-x 1 root root 89768 Apr 23 2024 /usr/bin/ping
      getcap
      /usr/bin/ping
      /usr/bin/ping cap_net_raw=ep
      grep FpingLocation
      Can we assume that there are some problems with apparmor or systemd unit
