Zabbix High Availability
  • Mun
    • Sep 2016
    • 67
    Anyone can help me on this?
    I want to do the Zabbix high availability as refer to the blog here >> https://ericsysmin.com/2016/02/18/co...r-on-centos-7/.
    In my case, my zabbix ha (1) : X.X.X.1 & my zabbix ha (2) : X.X.X.2
    In step 2, the instruction required to configure the SourceIP and ListenIP in /etc/zabbix/zabbix_server.conf, may i know what is cluster IP?
    SourceIP=<cluster_ip>
    ListenIP=<cluster_ip>
    Is it Cluster IP is referring to IP of zabbix ha (1)?
    Thanks.
  • toine7m
    • Feb 2017
    • 93
    Hi, if you read the article, you can see that the IP address he refer is specified a bit later at the step 3.
    The cluster_IP will be the IP of the main Zabbix, zabbix1 for example
