Zabbix server is running No
  • jhernandez686
    • Feb 2025
    • 9
    when i enter the log cannot use database "zabbix": its "users" table is empty
  • chintan1
    • Jun 2022
    • 24
    Have you followed these steps:
    Create initial database
    Documentation
    Make sure you have database server up and running.
    Run the following on your database host.
    # mysql -uroot -p
    password
    mysql> create database zabbix character set utf8mb4 collate utf8mb4_bin;
    mysql> create user zabbix@localhost identified by 'password';
    mysql> grant all privileges on zabbix.* to zabbix@localhost;
    mysql> set global log_bin_trust_function_creators = 1;
    mysql> quit;
    Added the db user and its password in config?
    • jhernandez686
      • Feb 2025
      • 9
      hi, thanx for your help, i tried but when i create de database zabbix said " error 1007 (HY00) cant create database, database exist,
      create user zabbix@localhost, error 1396 (HY00) operation create usear failed for 'zabbix'@'localhost'
      frant all privileges, command grant not found, did you mean gant, grunt, try apt install <deb name>
      • jhernandez686
        • Feb 2025
        • 9
        Finally its running, but it said localhost:10051 y enter netstat and 10050 and 10051 are in time_wait
