zabbix_agent2 installation
  • hubertsvk
    • Jul 2019
    • 15
    can someone tells me what I'm doing wrong?
    PS C:\Zabbix\bin> .\zabbix_agent2.exe --config C:\zabbix\conf\zabbix_agent2.conf --install
    zabbix_agent2 [2840]: 'Zabbix Agent 2' installed successfully
    PS C:\Zabbix\bin> .\zabbix_agent2.exe --start
    zabbix_agent2 [2356]: ERROR: cannot open configuration file: open C:\Zabbix\bin\zabbix_agent2.conf: The system cannot find the file specified.
    PS C:\Zabbix\bin>
    ... when I start zabbix services through services.msc it starts
  • Answer selected by hubertsvk at 08-07-2025, 13:45.
    cyber
    .\zabbix_agent2.exe --config C:\zabbix\conf\zabbix_agent2.conf --start
    Maybe?
    If you install service, it marks down config file location for service. But when you try to start from command line, you still need to point out config file... Otherwise it expects it to be in current directory, "C:\Zabbix\bin" in your case.
      Maybe?
