Includes at agent config
  • Tristis Oris
    • Sep 2015
    • 66
    We can include a custom config, but default `Hostname=Zabbix server` should be commented. Comments at included files is not processed, obviously.
    Any solution here?
    Solution to what? You forgot to describe your issue..
    • Tristis Oris
      • Sep 2015
      • 66
      i need to get a real hostname from host. What can be solved by commenting this line.
      • Tristis Oris
        • Sep 2015
        • 66
        lol. it works with empty value. I was sure that it's not valid, maybe long ago.
          Hostname
          Default: Set by HostnameItem
          HostnameItem
          Default: system.hostname
          system.hostname[<type>,<transform>]
          The system host name.
          Return value: String.
          Parameters:
          • type - possible values: netbios (default on Windows), host (default on Linux), shorthost (returns part of the hostname before the first dot, a full string for names without dots), fqdn (returns Fully Qualified Domain Name);
          • transform - possible values: none (default) or lower (convert to lowercase).
          The value is acquired by taking nodename from the uname() system API output.
          So leaving those undefined forces agent to use "defaults"...
