SOLVED: Zabbix "Agentless" SSL Certificate Monitoring
  • flakrat12
    • Jan 2025
    Howdy, I figured I'd share my notes setting up SSL certificate monitoring within Zabbix. This can be done without installing an agent on the remote sites/web servers by using a Zabbix Agent 2 (package `zabbix-agent2`) running on another system (including the Zabbix server) to act as a proxy.
    We are running Zabbix 7.2.
    Example, monitor the certificate on https://zabbix.com
    • Create a new host zabbix.com
    • Add to hostgroup: SSL Servers
    • Assign template: Website certificate by Zabbix agent 2
    • Interface: 127.0.0.1 Port: 10050
    • Click Macros and Inherited and host macros
      • Edit the value for {$CERT.WEBSITE.HOSTNAME} to zabbix.com
    • Repeat to add more sites...
    zabbix_get -s localhost -k web.certificate.get\[zabbix.com]
  • flakrat12
    • Jan 2025
    For clarity: In {$CERT.WEBSITE.HOSTNAME} replace <Put DNS name> with zabbix.com
    • seren
      • Jun 2023
      • 13
      Thanks for posting this. Doesn't the new host's name in Zabbix need to match the Hostname that the agent is configured with?
      So if you've created a new host zabbix.com, your agent would need to have Hostname=zabbix.com set?
      I ask because I'm trying to set up something like this using a different host (not the containerized Zabbix server) as the checking entity, but am running into problems connecting to the host.
      Thanks.
      • guntis_liepins
        • Oct 2025
        • 57
        Seren if you use passive check via zabbix agent interface Zabbix agent will not check which name you send in request, will just use agent access file (Server= directive).
        So name matters just for display, for request itself value of macro {$CERT.WEBSITE.HOSTNAME} will be used.
        I usually create group SSL_certs and just clone hosts there by changing name and {$CERT.WEBSITE.HOSTNAME}​​. It is indeed easy.
        • seren
          • Jun 2023
          • 13
          Ahh, thanks. I've been using active checks, but will try passive in this case.
