Issue monitoring map trigger state when is set as a symptom of another trigger
  • Ldzzzz
    • Feb 2024
    • 16
    I am experiencing an issue with the display of triggers on monitoring maps in Zabbix. Context:
    • I have a monitoring map containing multiple devices linked by triggers.
    • When these triggers are active, the link colors change correctly, and the affected devices are marked as "critical" (red).
    Issue encountered:
    • When I configure a trigger as a "symptom" of another trigger, it no longer appears as "critical" on the map.
    • As a result, the links on the map remain green instead of turning red, even though the issue still exists.
    Impact:
    • This misrepresents the actual state of the devices and can be misleading for monitoring purposes.
    • Alerts still work properly, but the map no longer accurately reflects the critical condition.
    Steps to reproduce the bug:
    1. Create a monitoring map with multiple devices linked by triggers.
    2. Activate a trigger and verify that the links and devices correctly turn red (critical state).
    3. Modify the trigger to set it as a symptom of another main trigger.
    4. Observe that the map no longer displays this trigger as critical, and the links remain green despite the persistent issue.
    Expected behavior:
    • Even when a trigger is set as a symptom, the map should continue to reflect its critical state if the underlying condition is still active.
    Do you have any idea ? There is still the issue in the next update ?
    • 5008
    Look around, maybe there is similar bug, then upvote it. Or submit yours...
