I wonder if Zabbix agent puts a load on system resources.
  • ywm
    • Feb 2025
    Hello.
    If the key of the Zabbix item is registered to find a specific string by giving 1 second of Update interval using logrt.count or logrt,
    If the Zabbix agent finds a specific string using the grep or find command of the Linux, I think it will affect the corresponding system resource.
    I wonder how Zabbix works for this behavior and whether it will not affect system resources.
    Thank you.
    • 5008
    It does not use grep and find... In general, agents footprint is quite minimal.
