I broke zabbix
  • jlkz
    • Mar 2016
    • 16
    I broke zabbix
    I tried to do an update following these instructions
    now when I try to go to the page it just shows the code.
    <?php
    ** Zabbix
    ** Copyright (C) 2001-2015 Zabbix SIA
    ** This program is free software; you can redistribute it and/or modify
    ** it under the terms of the GNU General Public License as published by
    ** the Free Software Foundation; either version 2 of the License, or
    ** (at your option) any later version.
    ** This program is distributed in the hope that it will be useful,
    ** but WITHOUT ANY WARRANTY; without even the implied warranty of
    ** MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    ** GNU General Public License for more details.
    ** You should have received a copy of the GNU General Public License
    ** along with this program; if not, write to the Free Software
    ** Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
    define('ZBX_PAGE_NO_AUTHORIZATION', true);
    require_once dirname(__FILE__).'/include/config.inc.php';
    require_once dirname(__FILE__).'/include/forms.inc.php';
    $page['title'] = _('ZABBIX');
    $page['file'] = 'index.php';
    // VAR TYPE OPTIONAL FLAGS VALIDATION EXCEPTION
    $fields = array(
    'name' => array(T_ZBX_STR, O_NO, null, NOT_EMPTY, 'isset({enter})', _('Username')),
    'password' => array(T_ZBX_STR, O_OPT, null, null, 'isset({enter})'),
    'sessionid' => array(T_ZBX_STR, O_OPT, null, null, null),
    'reconnect' => array(T_ZBX_INT, O_OPT, P_SYS|P_ACT, BETWEEN(0, 65535), null),
    'enter' => array(T_ZBX_STR, O_OPT, P_SYS, null, null),
    'autologin' => array(T_ZBX_INT, O_OPT, null, null, null),
    'request' => array(T_ZBX_STR, O_OPT, null, null, null)
    check_fields($fields);
    // logout
    if (isset($_REQUEST['reconnect'])) {
    DBstart();
    add_audit_details(AUDIT_ACTION_LOGOUT, AUDIT_RESOURCE_USER, CWebUser::$data['userid'], '', _('Manual Logout'),
    DBend(true);
    CWebUser::logout();
    redirect('index.php');
    $config = select_config();
    if ($config['authentication_type'] == ZBX_AUTH_HTTP) {
    if (!empty($_SERVER['PHP_AUTH_USER'])) {
    $_REQUEST['enter'] = _('Sign in');
    $_REQUEST['name'] = $_SERVER['PHP_AUTH_USER'];
    else {
    access_deny(ACCESS_DENY_PAGE);
    // login via form
    if (isset($_REQUEST['enter']) && $_REQUEST['enter'] == _('Sign in')) {
    // try to login
    $autoLogin = getRequest('autologin', 0);
    DBstart();
    $loginSuccess = CWebUser::login(getRequest('name', ''), getRequest('password', ''));
    DBend(true);
    if ($loginSuccess) {
    // save remember login preference
    $user = array('autologin' => $autoLogin);
    if (CWebUser::$data['autologin'] != $autoLogin) {
    API::User()->updateProfile($user);
    $request = getRequest('request');
    $url = zbx_empty($request) ? CWebUser::$data['url'] : $request;
    if (zbx_empty($url) || $url == $page['file']) {
    $url = 'dashboard.php';
    redirect($url);
    exit;
    // login failed, fall back to a guest account
    else {
    CWebUser::checkAuthentication(null);
    else {
    // login the user from the session, if the session id is empty - login as a guest
    CWebUser::checkAuthentication(CWebUser::getSession Cookie());
    // the user is not logged in, display the login form
    if (!CWebUser::$data['alias'] || CWebUser::$data['alias'] == ZBX_GUEST_USER) {
    switch ($config['authentication_type']) {
    case ZBX_AUTH_HTTP:
    echo _('User name does not match with DB');
    break;
    case ZBX_AUTH_LDAP:
    case ZBX_AUTH_INTERNAL:
    if (isset($_REQUEST['enter'])) {
    $_REQUEST['autologin'] = getRequest('autologin', 0);
    if ($messages = clear_messages()) {
    $messages = array_pop($messages);
    $_REQUEST['message'] = $messages['message'];
    $loginForm = new CView('general.login');
    $loginForm->render();
    else {
    redirect(zbx_empty(CWebUser::$data['url']) ? 'dashboard.php' : CWebUser::$data['url']);
  • jlkz
    • Mar 2016
    • 16
    Also when I run
    service zabbix-agent start I get an error
    job for zabbix-agent.server failed because the control process exited with error code. See "systemctl status zabbix-agent.service" and "journalctl -xe" for details
    • jlkz
      • Mar 2016
      • 16
      :~$ service zabbix-server satus
      chown: changing ownership of '/var/run/zabbix/zabbix_server.pid': Operation not permitted
      chown: changing ownership of '/var/run/zabbix': Operation not permitted
      Usage: /etc/init.d/zabbix_server {start|stop|restart|force-reload|status}
      • dushyant.parmar
        • Sep 2018
        i am facing same issue can any one help
        • cros
          • Jul 2017
          • 87
          solved ?
          i have the same situation.
          • Atsushi
            Atsushi commented
            Please make sure that the Web server and PHP execution environment are set to be linked.
        • jlkz
          • Mar 2016
          • 16
          I just started over and made one in a vm so i can back it up easier.
