Hello.
I ran into this problem, when setting up SMART monitoring on windows(I tried it on different versions OS windows):
The data is coming, but it does not have the correct format.
Ubuntu 24
zabbix server 7.2.4
zabbix agent2 7.2.3
smartmontools 7.4
template is SMART by Zabbix agent 2
Help me please
Cannot fetch data.: got error executing worker pool: failed to execute smartctl: "{\r\n \"json_format_version\": [\r\n 1,\r\n 0\r\n ],\r\n \"smartctl\":
{\r\n \"version\": [\r\n 7,\r\n 4\r\n ],\r\n \"pre_release\": false,\r\n \"svn_revision\": \"5530\",\r\n \"platform_info\": \"x86_64-w64-mingw32-2012r2\",
\r\n \"build_info\": \"(sf-7.4-1)\",\r\n \"argv\": [\r\n \"smartctl\",\r\n \"-a\",\r\n \"/dev/sda\",\r\n \"-j\"\r\n ],\r\n \"exit_status\": 4\r\n },\r\n \"local_time\":
{\r\n \"time_t\": 1740725274,\r\n \"asctime\": \"Fri Feb 28 09:47:54 2025 RTZ\"\r\n },\r\n \"device\": {\r\n \"name\": \"/dev/sda\",\r\n \"info_name\":
\"/dev/sda\",\r\n \"type\": \"scsi\",\r\n \"protocol\": \"SCSI\"\r\n },\r\n \"scsi_vendor\": \"Intel\",\r\n \"scsi_product\": \"Raid 1 Volume\",\r\n
\"scsi_model_name\": \"Intel Raid 1 Volume\",\r\n \"scsi_revision\": \"1.0.\",\r\n \"scsi_version\": \"SPC-3\",\r\n \"user_capacity\": {\r\n \"blocks\": 111357952,
\r\n \"bytes\": 57015271424\r\n },\r\n \"logical_block_size\": 512,\r\n \"scsi_lb_provisioning\": {\r\n \"name\": \"thin provisioned\",\r\n \"value\": 2,\r\n
\"management_enabled\": {\r\n \"name\": \"LBPME\",\r\n \"value\": -1\r\n },\r\n \"read_zeros\": {\r\n \"name\": \"LBPRZ\",\r\n \"value\": 0\r\n }\r\n },\r\n
\"rotation_rate\": 0,\r\n \"logical_unit_id\": \"0x61fa116d01000000001517ffff0aeb84\",\r\n \"device_type\": {\r\n \"scsi_terminology\":
\"Peripheral Device Type [PDT]\",\r\n \"scsi_value\": 0,\r\n \"name\": \"disk\"\r\n },\r\n \"smart_support\": {\r\n \"available\": false\r\n },\r\n
\"temperature\": {\r\n \"current\": 0,\r\n \"drive_trip\": 0\r\n },\r\n \"seagate_farm_log\": {\r\n \"supported\": false\r\n }\r\n}\r": exit status 4.
Ubuntu 24
zabbix server 7.2.4
zabbix agent2 7.2.3
smartmontools 7.4
Help me please
