JSON Items
  • bzp
    • Apr 2017
    JSON Items
    Hi there,
    I have a Zabbix active agent that has a UserParameter item defined that runs a Powershell script which returns a JSON object, as seen in the below example;
     "data":[
      {"sql-backups": "138"},
      {"sql-uploads": "138"}
    How can I setup host items to monitor these 2 values?
    I'm running Zabbix v3.2 server & agent.
    Thank you
  • dvg_lab
    • Oct 2017
    Hi bzp,
    Did you resolve it? I wanna do same things with JSON object.
