How to monitor percentage utilization of interfaces
  • FresKubas
    • Dec 2024
    Hello, today I installed Zabbix 7.2 upgraded from 4.2. In the old Zabbix, I had items to monitor the percentage utilization of interfaces using net.if.speed. Is it possible to use the same item in 7.2? I can't find it
    • 5002
    net.if.speed is not a built-in item... not even in 4.2... Was it a userparameter you had installed? It should work in newer version also..
    • FresKubas
      • Dec 2024
      From what I can see, net.if.speed is provided with the Zabbix agent template for Linux, but I can't find a host that supports it. I see the item reaches into /sys/class/.. but there's no information there about interface speed. On older machines, plain net.if.speed returns this information. Perhaps I just need to write a separate script to check interface speed and then create a calculated item to calculate percentage utilization.
        • 5002
        https://git.zabbix.com/projects/ZBX/...at=release/7.2
        Interface {#IFNAME}: Speed It indicates the latest or current speed value of the interface. The value is an integer representing the link speed expressed in bits/sec.
        This attribute is only valid for the interfaces that implement the ethtool get_link_ksettings method (mostly Ethernet).
        Reference: https://www.kernel.org/doc/Documenta...ysfs-class-net
        Zabbix agent vfs.file.contents["/sys/class/net/{#IFNAME}/speed"]
        Preprocessing
        • Custom multiplier: 1000000
        • Discard unchanged with heartbeat: 1h
        mentioned file in this item contains IF speed...
        There is no such item as net.if.speed. And never was...
        • SpaceKnight
          • Aug 2026
          Need some help. I'm in the process of migrating my network to Zabbix. There are more than 13,000 interfaces across more than 200 nodes.
          The challenge I'm facing with utilization alerts is that I can't use the Speed item to determine the percentage utilization of an interface, especially for LACP bundles and trunk interfaces, since these bundles consist of multiple physical interfaces.
          For example, let's say I have four 10 Gbps links configured as an LACP bundle. The physical capacity of the bundle is 40 Gbps, but I have only purchased 30 Gbps of bandwidth. The additional interface is part of the bundle for redundancy, so that if one of the links goes down, the traffic remains unaffected.
          Therefore, I want my interface utilization alerts to be calculated based on the actual purchased bandwidth rather than the physical capacity of the bundle.
          For example:
          Percentage Utilization = Current Utilization ÷ Actual Purchased Bandwidth × 100
          In this case, the utilization should be calculated against 30 Gbps instead of the bundle's physical capacity of 40 Gbps.
          I would like to know the recommended way to implement this in Zabbix.
          • troffasky
            troffasky commented
            I think this really needs a new thread, as it's not particularly related to this one.
          • 5002
          So don't multiply by 100... try 75... Or my coffee has not kicked in yet...
          • SpaceKnight
            SpaceKnight commented
            Thanks ! but it won't calculate the correct utilization if you meant; % Util = (Current Util / Interface Speed) * 75
        • troffasky
          • Jul 2008
          • 640
          I think you want to reference a macro in your template trigger definition. Then at host/interface level, override the macro with whatever the correct number is.
          • troffasky
            • Jul 2008
            • 640
            This is already done in factory templates.
            Problem: (avg(/Interfaces by SNMP/net.if.in[ifHCInOctets.{#SNMPINDEX}],15m)>({$IF.UTIL.MAX:"{#IFNAME}"}/100)*last(/Interfaces by SNMP/net.if.speed[ifHighSpeed.{#SNMPINDEX}]) or avg(/Interfaces by SNMP/net.if.out[ifHCOutOctets.{#SNMPINDEX}],15m)>({$IF.UTIL.MAX:"{#IFNAME}"}/100)*last(/Interfaces by SNMP/net.if.speed[ifHighSpeed.{#SNMPINDEX}])) and last(/Interfaces by SNMP/net.if.speed[ifHighSpeed.{#SNMPINDEX}])>0
            Recovery: avg(/Interfaces by SNMP/net.if.in[ifHCInOctets.{#SNMPINDEX}],15m)<(({$IF.UTIL.MAX:"{#IFNAME}"}-3)/100)*last(/Interfaces by SNMP/net.if.speed[ifHighSpeed.{#SNMPINDEX}]) and avg(/Interfaces by SNMP/net.if.out[ifHCOutOctets.{#SNMPINDEX}],15m)<(({$IF.UTIL.MAX:"{#IFNAME}"}-3)/100)*last(/Interfaces by SNMP/net.if.speed[ifHighSpeed.{#SNMPINDEX}])
            To override, you define a macro $IF.UTIL.MAX:"{#IFNAME}" on the host, where {#IFNAME} is the interface name as discovered by Zabbix.
            • SpaceKnight
              Thanks! I haven't started exploring macros yet, but I will definitely check them out.
              However, I found a somewhat dumb workaround. I added a static calculated item named Assigned_bandwidth_30Gbps to the host and set its value to 30000000000 bps, then used that item in the trigger. It worked fine.
