Interface discovery creating graphs
  • midnight_man
    • Mar 2016
    • 11
    I have mikrotik template for zabbix which is automatically creating graphs for all interfaces of routerboard.
    But I have little problem...I dont want to create RSSI, signal strenght for ethernet interfaces.
    How I can set this thing?
    Because now every items and graphs are created for every interface inside board. Zabbix cannot recognize if interface is ethernet or 80211.
    But:
    There is snmp oid for every interface, result of this oid is integer and there are 3 possible outs:
    ethernetcsmacd (6)
    ieee80211 (71)
    bridge (209)
    How I can tell zabbix that RSSI, signal and other wireless thing....I want it only for ieee80211 (71) interfaces?
    Thanks!
  • A.Zabihi
    • Aug 2016
    • 14
    But:
    ethernetcsmacd (6)
    ieee80211 (71)
    bridge (209)
    Thanks!
    hi dear,
    you must create Value mapping in zabbix administration->general and then select value mapping and create your own value mapping and in the item prototype in your template choose your value map in item creation level.
    thanks
    • midnight_man
      • Mar 2016
      • 11
      thanks for info...but I not understand principe of your solution..can you explain it more detailed?
      thanks
      • A.Zabihi
        • Aug 2016
        • 14
        thanks
        please give me more information, i think you need use better snmp discovery rule, but my information for creating this discovery rule for you is very little.
