Hello, Zabbix Community,
I am trying to set up monitoring for an Aruba 650 controller using Zabbix via SNMP. My goal is to track the number of connected users and create a graph in Zabbix to visualize this data over time. What I Have Tried So Far:
If anyone has experience monitoring Aruba controllers with Zabbix and can point me in the right direction, I would greatly appreciate it. Also, if someone has a working Zabbix Template for Aruba 650, sharing it would be extremely helpful.
Thank you in advance!
Best regards!!
- Enabled SNMP on the Aruba 650 and tested basic connectivity.
- Used snmpwalk to retrieve available SNMP OIDs, but I am unsure which specific OID reports the current number of connected users.
- Checked Aruba MIBs, but I couldn't identify the correct OID for this metric.
- What is the correct SNMP OID to retrieve the number of currently connected users on Aruba 650?
- Has anyone already created a Zabbix Template for Aruba controllers that includes user monitoring?
- Any additional tips on how to structure a Zabbix template for Aruba 650 to monitor user connections efficiently?
Best regards!!
