Zabbix DB upgrade from v3 to v6
  • Tekigw
    • Mar 2025
    Hello all, I need a little bit of your wisdom.
    I've got a task to upgrade Zabbix from version 3 to version 6 and migrate it to the cloud. I've created a replica of the current production monitoring server, upgraded Ubuntu from 14 to 18, upgraded MySQL from 5 to 8, imported the old Zabbix database, and upgraded Zabbix from version 3 to 6. However, for some reason, the upgrade didn't update the database version, so now I need to do it manually.
    I found out that I can't upgrade it directly from 3 to 6; I need to do it step by step—from 3 to 4, then to 5, and finally to 6. I tried cloning the Git repository (https://git.zabbix.com/scm/zbx/zabbix.git) to use the scripts from zabbix/database/mysql/upgrade, but I didn’t find the SQL scripts there. I also couldn't find any information about this in the documentation.
    Could you please help me?
  • tim.mooney
    • Dec 2012
    • 1430
    You should never need to upgrade the database manually. It's possible, but it's not how the product is designed and you would have to have a very deep understanding of each schema change.
    When you started zabbix_server version 6.0.x on the replica, it should have connected to the database and started applying a lot of upgrades. Are there log messages in /var/log/zabbix/zabbix_server.log about any particular upgrade that failed?
    That's incorrect. You absolutely can upgrade directly from 3.0.x LTS to 6.0.x LTS.
    The complicated part about making a huge version leap is that you have to read all of the upgrade documentation not just for version 6.0.x, but for every release between 3.0.x and 6.0.x: https://www.zabbix.com/documentation.../debian_ubuntu
    It can sometimes be less intimidating to break the upgrade into steps. Since you're upgrading a duplicate system, not the original, you can reset the database to an empty database on the new system and re-try your upgrade after you figure out why the upgrade failed in the first place.
    You didn't find them because they don't exist, at least in the form you're looking for. The upgrades aren't in a bunch of SQL files, they're in C code using a bunch of upgrade helper functions.
    Manual upgrade of the database is not how the product is designed.
    • Tekigw
      • Mar 2025
      Yes, I agree that I would have to have a deep understanding, but I don't. Actually I didn't work with zabbix lower then version 6 and everything there are very "admin friendly", but unfortunately the situation is like "You should upgrade and migrate, here is a server, have fun". So I'm trying to find a solution.
      Maybe there is a way to just set up a new zabbix server and then import there old monitoring in some way?
