Monitoring Dell PowerEdge MX7000 by SNMP
  • cooljay
    • Mar 2025
    Hello.
    I would like to monitor our Dell PowerEdge MX7000 machine by SNMPv3.
    I have successfully enabled SNMPv3 connection with Zabbix, but I am struggling to collect some relevant data.
    This PowerEdge has OpenManage Enterprise (OME) Modular GUI. So I have tried to link template "DELL OpenManage by SNMP", but that didn't work.
    I have Zabbix 7.0.10 so I imported the updated version of the template from here: Zabbix SNMP monitoring template for DELL Openmanage Server Administrator · GitHub (last comment).
    But this doesn't work, items have Not Supported status and it says "No Such Object available on this agent at this OID".
    I have downloaded the MIB file from the machine so I can build my own template, but it would take some time so it's my last option (i would need to install mib2zabbix​ first).
    So my question is, does anyone have any solution/template that's working for MX7000 on Zabbix 7?
    Thank you.
  • Mansoor Khan
    • May 2025
    Hi cooljay, Did you find a way forward with this? I need the same template of Dell MX7000 chasis for Zabbix!
    • cooljay
      • Mar 2025
      Hello.
      I managed to generate a template from the MIB file.
      I have uploaded it to the attachments if you want it too.
      It works well with SNMPv3 AuthPriv
      • 9l843pgdk
        9l843pgdk commented
        Things are not coming with the PSU, are you having problems?
    • Mansoor Khan
      • May 2025
      Hi cooljay,
      Thanks for sharing the template. I’m on Zabbix 7 now, and unfortunately, the template isn’t importing—it’s throwing errors during the process. Would you happen to have a working version that’s compatible with Zabbix 7?
      • cooljay
        • Mar 2025
        Hello, I attached the template that is working for me at Zabbix 7.0.
