Zabbix monitoring website SSL related ( without zabbix agent )
  • Frank_Cj
    • Mar 2025
    Hi, I am using Zabbix to monitor a website "HTTPS service is running" and "SSL cert validity" (how many days to expire).
    it occurs a weird problem that the HTTPS service is down, but the SSL cert validity is 192 days.
    Does anyone met this problem too and knows why? please help
    I am a junior Zabbix user. Thanks everyone
  • Viktors Fomics
    • Oct 2025
    • 52
    Hello
    Those processes are pretty much independent: TLS handshake can still happen if HTTPS service is down, therefore SSL certificate information can be retrieved and this check can be successfully made.
      • 4993
      Without agent? How is your monitoring built?
      Usually if your webserver is down, no port answers and you cannot do any handshake or anything... But if you check for a cert by some other means, then it might be possible to get the value...
      • Viktors Fomics
        • Oct 2025
        • 52
        That's only true if the webserver handles the TLS connection, but if there is a layer in between like load balancer, firewall or anything else, that can handle the TLS, then the certificate check will be an independent thing from the webserver availability check.
          • 4993
          Lets not overcomplicate things..
