Zabbix with VMware vSphere
  • Maatel_IT
    • Mar 2025
    Dear Everyone !
    I have successfully inventoried my vSphere environment in Zabbix, and all my virtual machines have been detected successfully. However, I am unable to view the graphs and dashboards. Do I need the Zabbix agent on each machine to collect this data ?
    As you can see, on a host the options Graphs and Dashboards are shaded :
    Click image for larger version  Name:	image.png Views:	0 Size:	1.2 KB ID:	500820
    Is there an option to access graphs and dashboards without requiring the Zabbix agent ?
    Additionally, is it possible to monitor vSphere virtual machines in Zabbix via SNMP instead of using the Zabbix agent? (For example, on a discovered machine, I cannot modify anything since it is detected through vSphere.)
    Thank you in advance for your help.
    See you soon
