Monitor Hardware IPMI vs SNMP
  • thunder
    • Apr 2017
    Hi all,
    We own a couple of SUN servers which we'd like to monitor with zabbix for disk, power supply failures etc.
    Our servers support both SNMP and IPMI. Unfortunately, there are no templates on share.zabbix,com. What should I use? SNMP or IPMI? What are the advantages from one over the other? Which one is better?
    Thanks for any feedback!
    thunder
  • batchenr
    • Sep 2016
    • 440
    Originally posted by thunder
    Hi all,
    thunder
    for snmp youll have to get this device MIB file, there you have all objects that
    you can monitor. do u have it ?
    • thunder
      • Apr 2017
      Yes! I can download the MIB files from the iLOM interface. What's the advantage of using SMNP over IPMI?
      • ovas
        • Apr 2017
        • 138
        You can compare the data you are able to collect with IPMI with the data collectable from SNMP, then make decision from there.
        Aside from that, with IPMI you would be able to execute remote commands, whereas SNMP only allows you to collect the data stored. SNMP checks on the other hand can be extended at your wish.
        For the described task you can actually use any of them.
        • A.Zabihi
          • Aug 2016
          • 14
          sensors with snmp monitoring is faster than IPMI monitoring but IPMI onitoring is very powerful monitoring way and you can use ipmitool in your linux server like :
          #sudo apt-get install ipmitool
          #ipmitool -H 10.10.10.10 -I lanplus -U <username> -P <password> sensor
          #ipmitool -H 10.10.12.3 -I lanplus -U <username> -P <password> sdr list all
          thx
          • MR_Andrew
            • Dec 2015
            • 27
            Hello!
            Thanks for this topic!
            I have the same question. I have Dell iDRAC 5 and 6, HP iLO cards.
            But I'm newbie with IPMI.
            I have good experience with SNMP and understand how it works. But any experience with IPMI.
            In templates for Dell and HP, that I found, SNMP method is used.
            So, what's better - SNMP or IPMI?
            On of advantages of SNMP that I will use - SNMP traps. Hope I will understand how to setup it. But what should I use for active monitoring?
            Thanks a lot!
            • neogan
              • Sep 2011
              • 118
              Hi Andrew,
              There are not many advantages for using IPMI, there are fewer metrics which you can get from server, but IPMI can reboot the server and tell what happens with it if OS hung.
              On the other hand, SNMP provides more parameters which you can get from the device.
              So get all counters with ipmitool and snmpwalk then compare them.
              • MR_Andrew
                • Dec 2015
                • 27
                Originally posted by neogan
                Hi Andrew,
                Thanks you very much for your reply!
                So, looks like new adventure called "IPMI" is waiting for me
                Will try both methods. And hope Zabbix configuring for IPMI working will not be too difficult
                • mykolaq
                  • May 2015
                  • 69
                  And there is more easy LLD with SNMP and more examples.IMHO
                  • Vaku
                    • Feb 2018
                    • 24
                    This is BS and not true.
                    Ignore this comment, because it's wrong.
                    SNMP does also allow executing remote commands. There are writable OIDS, that execute specific functions.
                    That's why there are permission levels for SNMP - read/write/execute.
                    In practice, I have configured Zabbix to automatically launch APC InRow (our backup conditioner) through SNMP command, when server room temperature raises up to 25C degrees.
                    This works awesome, as a thermostat controller.
