Hi folks!
I'm totally new to zabbix and so far I'm really happy with the system.
I'm stuck now with some SSL-Certificate problem on my ESXi hosts.
All of my hosts are using their default SSL certificate, provided by VMware.
The simple check items in the VMware Templates are returning the info: "Couldn't resolve host name".
DNS and network settings are fine. Resolving hosts works perfectly on the shell.
I figured out, that curl has a problem while trying to get data via the SDK-Url from the ESXi hosts.
Executing
returns me
Executing
<- Option -k ignores SSL-Errors
returns me no error.
Is there any chance to tell zabbix to use curl with the "-k" option?
Or are you all using ESXi with new own certificates?
Thanks for your help!
System: Zabbix 3.2, Ubuntu 16.0.4.LTS, ESXi 6.0.0
Executing
curl https://DELL1/sdk
curl: (51) SSL: certificate subject name (localhost.localdomain) does not match target host name 'DELL1'
curl -k 'https://DELL1/sdk/'
